TwinTurbo.NET: Nissan 300ZX forum - i came across some studs that were apparently red loctited
gt300zxtt(HI)
on April 06, 2013 at 2:07 AM
Removing stuck idler studs?
posted by evan_aggie
on April 04, 2013 at 10:54 PM
i removed the upper stud using a combination of the double nut and vice grips. the lower one would not budge. i ended up having to use a torch along with the double nut method.
evan_aggie
22:54:01 04/04/13
Sounds pretty stuck. I've always been able to remove them
Evan_Wright (Ca)
23:03:25 04/04/13
I seriously considered not trying to swap them in fear
evan_aggie
23:06:10 04/04/13
Re: Sounds pretty stuck. I've always been able to remove them
JSD-ZX
01:09:18 04/09/13
tighten two nuts together
Khronik
01:20:35 04/05/13
Overnight PB blaster soak appeared to work. Man I hate
evan_aggie
19:59:49 04/05/13
Heat up the studs, then spray penetrent while still hot (n/m)
ZaXxon
08:26:26 04/05/13
I'll give that a try when I get home this afternoon. Thanks. (n/m)
evan_aggie
08:58:44 04/05/13
the way I do it
Zvil (FL)
16:08:46 04/05/13
I don't weld. The longer stud is still stuck. Do you think
evan_aggie
17:43:48 04/07/13
Who knows.... you might get lucky
Zvil (FL)
21:34:19 04/07/13
one more thing you might want to try is
Zvil (FL)
21:39:16 04/07/13
Finally turned! I threw caution to the wind and torched it
evan_aggie
22:03:21 04/07/13
i came across some studs that were apparently red loctited -
gt300zxtt(HI)
02:07:37 04/06/13
Both nuts keep spinning on the bottom stud. I tried to get
evan_aggie
17:58:16 04/07/13
